Root Rebooting Issue
Scorpion34
Member
I just got rooted 3 days ago. I'm running the latest Velocity. Everytime the phone reboots, whether manually or not, it comes back on and I have to redo all of my widgets. If I'm running Launcher Pro it will say "problem loading widget"
One of my widgets I have restore & reinstall everytime I reboot. It's like the phone is wiping the info clean everytime it has to reboot. It's kinda annoying.
Has anyone else had this issue
Sounds like you're running widgets from appps stored on sd card, and that don't work too good! Keep apps with your widgets u are using on internal memmory and you'll be good to go! I know that kinda sucks but give it a shot. I had to figure the same thing out with trial & error. Hope that works for ya holmes!
Yeah that does but I'll give it a shot. Thanks guys.
One more question, should I also move Launcher Pro to the internal memory? since it won't show til I press te home button or just leave it where it's at?
