More info would really be helpful. How does it work? Take a picture, etc.
I read about the frequent rebooting somewhere else too. Hope that's not a serious issue.
Will this GPS dongle be sent out to all owners?
Or owners of older S/N's? (mine is only one week old)
Thanks.
Tried to register today. Website would not accept the S/N.
Sent e-mail to customer service.
Are you sure that you read the S/N properly? I misread mine the first time that I put it in and it wouldn't take it. Make sure that all your 0's aren't O's and vice versa.
Are you running the latest software update?
What you need to do is 'Reset' your Prime.
Simply insert a paperclip end into the small hole beneath the MicroSD card slot.
Don't worry, it won't delete any of your files.
That should clear up the problem and your Dongle will then start to pick up Satelites.
You sure it won't delete anything? I have no problems locking onto a satellite. It's Google maps that keeps searching and never finds directions.
I'd say that mine is working excellent from indoors with the new extension.
I didn't have WiFi on. I guess that must be the reason. I thought it would be like most gps devices where you don't need wifi. I have a mobile broadband device I will try after leaving work today.If you are trying to get a route through Google maps you have to have WiFi on until you get the route data. If you turned off WiFi and tested your GPS then didn't turn it back on before entering your destination that may be your problem. I've done that on my phone in the past and you are describing the exact same thing I saw on my phone.
