Help Recieving a txt
nick99wj
When recieving a txt message, I'm not a fan of having to swipe down to unlock and then down again on the notification bar and then tap the message. Is there anyway to set it so that swiping the lock bar UP goes straight to the coversation in the messages program.
Right, and I only need to see one more word to figure out what they are saying, but it takes 5 more steps to get there.
Yeah. I'm new to smartphones / Android, and am very hesitant to use something that drastically changes how the phone is used. I guess I am fearful from a history of using computers, and then not knowing if I'm missing out on the OEM method.
Is there any way to stop the incoming text messages from showing up in three places using handcent? 1. notification bar 2. Inc messages icon 3. handcent icon. It's alot of work having to clear all the messages.
Open the stock messaging app. Make sute u're in the inbox. Hit the menu touch button. Go to settings then turn off notifications. Then only the handcent notifications will be shown.
if you are using handcent then why keep the oem messages icon? do like short said and disabled the notifications for it but also remove it from the screen...the handcent notification bar status will clear after you exit the quick message or reply to the message.
