Jon_LTD
Android Expert
Hi all
Yesterday, I spent a good proportion of the day rooting my girlfriends wildfire and installing a Rom, as her Stock rom was getting laggy and crashed frequently etc. At the moment I've installed another Sense Rom but she is keen on using Go Launcher. IMHO, Sense is a bit of a heavy interface and full of bloatware which needs to be stripped - and little to no point using a Sense Rom if you favour Go Launcher.
Can anyone recommend any AOSP rom which is: Lightweight (basics only) and stable (so preferably not a beta - but will consider it if it's considered stable). I've had a look at the list on the XDA website (here) and none of the 7 AOSP roms tick the boxes. I've used CM7 before (on my Desire so not sure if it's the same on the Wildfire) but this seems like the only option close to what I'd like. Is this the case?
Many thanks for all your input.
Jon
Jon
Not to sure on that one.
