Recommendations for arm-bands, for running with phone
DesireMe
Android Expert
As per title. Just after one of those arm pouch things to put the phone in whilst running. Anyone recommend a good one?
Hi posted this a while ago, still works fine for me and as a Barely There case doesn't increase phone size by much, should be fine for an XE without any case.
Found one .... !
Just brougt a 'Tune Belt' from Amazon which comfortably holds the XE even with a Casemate on ... There are lots of types available both from them and other sellers but I found a model (TuneBelt AB84) which says it will suit an Sensation & 'icrap 4' with an Otterbox Defender case on, and if you've seen a Defender case before, that makes even the slimest phone look big.... A point to bear in mind though, if you have massive biceps, you will need the 'extender' strap to get a good fit. Only just got it today but first impressions are good.
__________________
If this has helped, hit the thanks button, it's only small but it means a lot....
