I purchased a used Optimus T last week that had been factory rest. I was able to easily root it using z4root and I then installed setCPU to overclock it. Being a novice, I assumed that would work, but setCPU cannot gain access to the processor speed above the stock 600Mhz. So, I am assuming I will need to replace the stock ROM first which is probably blocking access. The kernal is Linux 2.6.32.9 from lg-electronics. all other software is up to date per a check prior to rooting.
I would appreciate recoomendations from people that have done that on this phone. I am looking for a reliable ROM that is efficient with the least amount of problems with installed typical android apps. Thanks for your help
