jordanretro3
I was using mikmik but 4g is not working properly. Any suggestions concerning roms that are constantly updated?
First rom that comes to my head is Decks Reloaded that will be updated soonI was using mikmik but 4g is not working properly. Any suggestions concerning roms that are constantly updated?
Mikg has working 4g. If it isn't working for you, you may have lost your wimax keys
yes 4g works for me but i am having issues with wifi thether.
no worries, now go and get your flash on![]()
Ive tried the instructions with deleting the entry in root. still no luck
I swear sprint has capped my data. because it was working before now it hasnt worked in a month.
