Hi,
Am new to the forums so sorry if in wrong area.
Am looking into inductive wireless chargers for my Galaxy S4. Don't know too much about these so would appreciate recommendations on which are good units to go for from people who have used similar things.
Thanks
If I buy that OEM backplate from Samsung will a Seidio Surface case fit and will it charge through that case? I'm guessing my answer to both is probably no but like the idea.
How thick is the case?If I buy that OEM backplate from Samsung will a Seidio Surface case fit and will it charge through that case? I'm guessing my answer to both is probably no but like the idea.
I saw the post above from Seidio saying it wouldn't work (which is very honest of them) but I wouldn't have thought a thin case would stop it working completely unless it is made of certain metals.
The magnetic field is inversely proportional to the square of the distance from the charging coils so the effectiveness of charging would decrease very quickly the further the coil is away from the pad but I know others here have found that a thin plastic case didn't stop wireless charging from working although it would slow it down.
The problem is not that the case is to thick for charging. It is that the backplate makes the phone to thick to fit.
I don't understand why Samsung couldn't have either made the stock battery door thicker to match the wireless charging cover, so cases designed for stock GS4 would still fit?
Because making the phone thinner is an important to the tech press.![]()
