Recommended reading on task killers
In summary:
If you're too tech illiterate to create proper ignore lists and set the manual mode for a task killer you should root, swap out the ROM and alter the CPU settings. What could possibly go wrong?
I understand that alot of people think that killing the apps helps the battery but in my case i use it to speed the phone up. It may or may not actually be working but to me it seems like it does. I have a list of apps that are on the "ignore" list on the app killer and they are ones that i trust and haven't had any issues with.
