Recommended SD Card for Esteem?
Bard
Android Expert
Is there any specification for LG Esteem's SD Card Class?
I just went through the manual; it says they support up to 32 GB storage but doesn't say anything about the class.
I shoot family movies and photos. And watch movies from SD card. That's about it.
Will cheaper class 4, 6 be just enough? Or better investing on class 10 for few more bucks?
What kind of Micro SD card do you guys have in your Esteem?
Thank you.
yea really dont worry about class i have class 10 and have used class 4 and 6 before and to be honest i havnt noticed no difference.
You wont notice a difference unless you store most your apps to SD and read run them straight from there, then "maybe" but I personally think the class 10 is way over priced for what it is. :D
