Root recommended stable/clean rom
Dinc is rooted with unrevoked and I was looking for a nice clean stable rom. Something like stock without all the bloatware but with some customization. I was also fond of the watermark'd theme but I can't seem to find it on the Dinc roms. I'd also hate to lose anything like 720p recording, gps strength, bluetooth, etc... Seems skyraider is popular but I hear there won't be anymore updates so I'm straying away from that.
Virtuous is a stock ROM stripped of bloat with some added customization. Skyraider is a near flawless ROM. There is nothing to update. Don't let the fact that ihtfp69 is no longer working on it scare you.
do you know if you lose anything from virtous or SR? I heard of one that doesn't allow 720p recording and another that had bluetooth issues but I forget which ones...
No issues with Virtuous AFAIK. You do lose the bloatware. ;)
Virtuous is a great starter ROM because it's similar to stock, has easy customization options, and does not require a full wipe if flashed over stock. It can be downloaded and flashed using ROM Manager (which is not recommended for a lot of other ROMs) or directly from clockworkmod recovery. Alternatively, or after you are comfortable with flashing ROMs, Incredibly Reengineered is another great choice for a stable Sense ROM.
I had issues with virtuous and adw ex (constant force closes) so I flashed with skyraider. WOW, what a difference. not a single force close and hulu is sweet. very stable. Just wish they had some themes for it... watermarkd would be nice.
