D Derrikjb Lurker Nov 13, 2011 #1 I have the LG G2X, standard no root or custom ROM. I was wondering if there was any possible way to record more than 30 Minutes of video? Thank-you in advance.
brezzo Well-Known Member Nov 14, 2011 #2 Your memory card is probably the limit, because high quality video takes a lot of space.
J jackdsparker94 Well-Known Member Nov 14, 2011 #3 I think if you put your video quality down you might get more
D Derrikjb Lurker Nov 14, 2011 #4 I have a 32GB Micro SD card. Plus the standard internal Memory which has 3.77GB left. The Lower quality still only allows for 30min of record time. Is there anyway to alter the limits if i root it, or an app that will allow for more record time? Thank-you for your replies 8)
