Help Record you phone call?
I down loaded "Auto Call Recorder" and I have tested it once, seem to work good. It does have a lot of features.
It seems very handy since it will automatically start recording when you place or receive a call, you can also build a list of calls to record based on your contacts. I am playing with that now.
I think on most phones you have to record through your mic so this requires you speaker to be on so it can record both sides of the conversation. I believe this also excludes the use of blue tooth.
Just for reference and knowledge
"The U.S. federal law allows recording of phone calls and other electronic communications with the consent of at least one party to the call. A majority of the states and territories have adopted wiretapping statutes based on the federal law, although most have also extended the law to cover in-person conversations. 38 states and the D.C. permit recording telephone conversations to which they are a party without informing the other parties that they are doing so.
12 states require, under most circumstances, the consent of all parties to a conversation. Those jurisdictions are California, Connecticut, Florida, Illinois, Maryland, Massachusetts, Michigan, Montana, Nevada, New Hampshire, Pennsylvania and Washington.
It is illegal under all jurisdictions to record calls in which one is not a party."
If you aren't in one of those 12 states, then does that mean that it's legal because you are consenting?
Also, if you have a ringback tone or message stating that "this call may be recorded for quality purposes" or something like that, does it make it legal?
I knows that this forum's stance on the subject is that they aren't enforcing against the discussion of this topic because of its grey areas.
Sorry for shifting the topic slightly, but how would we change our ringback tones? I was looking it up some time ago and didn't find anything, looking for "ringback tone" in the Play Store and I got things for normal ringtones (and an app called Hits Music Ringback Tone)
You actually has to add money to ur account in metro pcs store nd check metro studio theres an option to search for ringback tones m8
i was about to say F the feds!!! theres no need to discuss the disclaimer here there are a ton of them apps on the market he was only asking if any1 knew of a good working one nothing wrong with that...... anyways if u flash to the broken rom mt has added to the kernel the the ability to record calls all u would need to do is download an specfific app called callrecord it actually records the call within the call instead of using external speakers.
lol lets have a party :cool:
Is there an ap that works on the Esteem that lets you record a phone conversation?
Dont listen to anyone else!(no disrespect to other esteemers) Go to the markey an type in "skvalex" an download that call recorder. It will cost you but that the best call recording app I've found on the market thanks to someone on this site. You need a rom with the call recording patch in the kernel, Brokenout rom has it that what i use, I was told that it work on the other roms. Trust me I ran thru a lot of those recorders an this one is the best. It has a good number of options.
U just repeated what I said looool but good to know someone else is on the same side.
