@juddy i said so, as u replaced it 4 times and its the same issue.
did u come across any set that dont have the issue (from the store where u bought dont they have one on demo ?)
People wont notice it as it is a small high frequency hiss sound[May be people between some age group can only hear it LOL
If you capture a video under a noisy BG, u wont notice the hiss much. It gives the feeling that the sounds are so deeply captured.
What i came across is that, the hiss sound is coming from the left channel [Try with ur earphones while playing the captured video]
It should be something wrong with the noise reduction algorithm for one of the mic
Go to this link Got yourself a HTC... | Facebook and search for "Hiss", two guys have asked about the issue there
].If you capture a video under a noisy BG, u wont notice the hiss much. It gives the feeling that the sounds are so deeply captured.
