Good find Josh. I was wondering if we would get a touch CWM.
I installed it on my boss's galaxy SII yesterday and really like it.
Now it's just a matter of time before someone comes up with it.
I'm currently trying to build one for this phone using that. Will let you know if it works.
EDIT:
Ok got the recovery.fstab to work with the new recovery. (has correct formatting and the correct mount points for our phone). But now it seems we need a working graphics.c file. I have zero programming skills with the programming language this file uses. So someone more experienced needs to step in and see if one can be made/edited to work.
Here is the recovery.fstab file with the correct mount points:
When using the builder site, the input field for the recovery image, use the stock recovery image provided by the RUU.
Currently I got this version of CWM running on the phone, but touch functions don't work nor do any of the menu options work. (results in empty background with only the logo when going into any of the menus. Main menu is the only functional menu.
The version of CWM it makes isn't completely borked since I can still but up Android after pulling the battery and rebooting it. (since even the reboot phone option won't work in this version of CWM)
