Root Recovery Builder via Koush
Official build means ROM manager capabilities... If I read this correctly it should make an official build... I for one want ROM manager working
Duh, touch only works on Ice Cream Sandwich kernels or later. Oh, wait... This must mean we've always HAD ICS, it was just in disguise! I mean, look...
V6 - V4 = V2. Since our phone has 2 cores, 2*2=4, 4.0 is ICS, ergo, we have ICS. See, it all makes sense now...
Spectacular deduction...you are a gentleman and a scholar lol... :D
does this mean that all this time ive hed ics and sense and didnt even know it?? lmfao
Ok, so, finally got one to build correct. It loads recovery, mounts partitions, does nandroid, and what not, but there is one BIG change between this and the one most people use.
The power button turns off the screen. This means no more using the power button to activate menu choices.
Also, as i've tested, this version does not fix the CWM boot loop automatically. You still need to apply the .zip fix. As I mentioned before, the color is also inverted and would need someone with more experience then me to fix it. For those interested in messing with there phone, here is the link to the build.
recovery http://builder.clockworkmod.com/downloads/8758fc7a5b707812b80c3da470a779a4.img [Jenkins]
lol it just does what I did, and it will still have any issues the current one or mine has ;) and that alone will keep it from being official. Need to be able to boot into CWM if it wont boot into the OS ;)
Interesting.
thats incorrect, a 2.6.35.* works just fine ;)
the current cwm you all use is using a GB kernel as is the build I've done, as is the connects and lucids Official CWM Touch builds.
try using the graphics.c from my vs920 repo and the recovery.fstab. ;)
I understand now... 35 - 26 = 9. And you can do 9 * the amount of work you do at your job, you'll likely have the 4.0 or higher that it asks for. That is unless you are a NYS highway worker, which in that case it would be like 9 * .2 if "amount of work" is on a scale of 1-10. Jees, they are on Android 1.8, sucks to be them.
I hope I cleared everything up for everyone, this was a lot of work. I must be on Android 90.0. Or actually since I did this post AT work, maybe I'm only on Android 2.6.35.*... Oh snapz...
Actually i was talking about kernel versions lol
how do i flash cwm recovery to my cell(xolo a700) which i got from this site
builder dot clockworkmod dot com
my build number is 5f46032aac1bb73609c9bf425a961de1
please help !!
