Root [Recovery] CWM v6.0.5.1
phenomx4
Android Expert
Recognized Developer
CWM is a custom recovery that allows you to flash custom roms and to backup and restore a nandroid.
This has swipe options enabled for easier use.
Usage:
Swipe up for up.
Swipe down for down.
Swipe left for back.
Swipe right to confirm/select.
You can also use the capacitive and hardware keys.
Usage:
Back for back.
Home/Vol Up for up.
Menu/Vol Down for down.
Power for confirm/select.
Download:
https://s.basketbuild.com/filedl/devs?dev=phenomx4&dl=phenomx4/N800/CWM-v6.0.5.1-N800-12-27-14.zip
Usage:
Swipe up for up.
Usage:
Back for back.
Home/Vol Up for up.
Download:
Flashed. The candy update with cwm worked great:)
I like PhilZ Touch 6 Recovery. There was one made for are phone but it had the formatting issues like the older cwm. To bad it's no longer being developed.
@phenomx4 I tried spirit rom and it flashes OK but hangs on the Green Android with the led solid red.
Update:
Latest spirit rom from today flashes correctly and boots. Works great so far. I will probably stay on it or slimkat until things like lucky patcher and xposed modules work on lollipop. I miss them lol.
