Root Recovery error
ccsoccer03
"error : run 'nandroid-mobile.sh restore' via adb "
I get this when I try to restore a "nand +ext backup + .android secure" Backup. Whats up with that? I restore nand+ ext backup and just regular nand fine?
Ive gotten that a few times. Maybe that backup got messed up/corrupted? I dont know what it means. Most of the time i was able to reboot recovery and restore. And a few i just had to delete that backup. Are you using apps2ext? Are you not on froyo?
I've had the same issue with backups made of velocity 1.0. Even run into the issue with backups made using adb, using the script from adb in recovery
Code:
nandroid-mobile.sh --backup
