Root Recovery for commando
Understood, thanks. I just did a Google search "baseband unknown fix after nandroid restore" and THIS thread popped up already! I'll look around some more...
Rjglenn, I'm not at my computer but if you feel like searching around for a way to explore the md5 file, maybe there is an identifier for baseband or serial number? Just trying to brainstorm some ideas that might help make progress. I'll start looking when I get home. Thanks again for the help guys
Looking at other threads I found one about flashing an "amss.mbn" file to fix the "baseband unkown" problem, and another thread about flashing the radio.zip file (contains radio.img) after loading a custom rom. Both threads may be related to our problem:
Please Help... Cant still figure out - Android @ MoDaCo
and
Radio_Update - android-roms - How To: Install a Radio Update. - Android ROMs will host updates to the OS both Custom and Offical. - Google Project Hosting
Maybe we need to re-flash a baseband file? (just brainstorming too, Spike)
The commando on 2.2.1 with all the bloatware removed runs very well with no lag, no stutter and no crashes. It seems to have better battery life too. The commando running 2.3.3 has some stutter and lag, and seems to use more battery. My experience had been that it has some force close issues with some applications that it did not have on 2.2.1. I actually prefer the status bar on 2.3.3, but other than that I see no improvement.
Others may have had different experiences and may think I am totally wrong. YMMV.
While I prefer the 2.2.1 status bar, I otherwise agree with what rjglenn said.
2.2.1 was much faster, less laggy pretty much all the time, and had less force-closes. It also booted faster. Where I normally had 40%+ battery at the end of the day with 2.2.1 after removing apps, I am often at 20% or less with 2.3.3 after cleaning it up as much as I could. It's almost like someone added an app to 2.3.3 that ensures no improvement if you clean up the useless stuff. :)
2.2.1 was the high mark for me.
Thank you both for trying to make this work!
Flashing a radio from another model phone will have undesireable results (brick) and will probably not be correctable. DO NOT DO IT.
I do not have the technical knowledge to be able to extract the baseband out of the phone and then package it up into a flashable update.
This is a classic example of the Peter Principal:
"A man will rise to the height of his own incompetence and then peter out"
I've petered out...
I wasn't suggesting we use another model phone's baseband to flash, I agree that would be a bad idea. Until someone less technically challenged than I am stumbles onto our thread, I think I'll go create a dual boot CM7 SD card for my Nook Color which should be arriving in a day or two :D.
If you have recovery installed on the phone, you should be able to call recovery with adb using the command "adb wait-for-device reboot recovery". I have done this as a test and it works. Connect the phone to your computer, enter the command, and then power on the phone. As soon as the phone makes the USB connection to the computer it will reboot into recovery. Once in recovery use the menu to restore a nandroid. If you don't have a nandroid then you will need to ask for one. If you don't have recovery on your phone then I don't know what to tell you.
For anyone who's reading and has been hesitant to install the recovery that GNM has developed for us, this is why you should have a recovery on your phone if you are planning to do any "work" on it. It's more than just being able to install ROMs, it's about being able to fix mistakes.
I tried this with command prompt... I did the following:
cd "C:|Program Files\Android\android-sdk\platform-tools"
redirected to C:\Program Files\Android\android-sdk\platform-tools>adb wait-for-device reboot recovery
attached copy of screen print
the phone boots to the verizon intiating and nothing further.
adb status window show that it is [2j [2HAndroid Degug Bridge
were do i get the GNW recovery
You have to have the recovery installed on the phone to be able to boot into it. Follow the first post on this thread to CNM's post area. On that thread you will find instructions and links to download the needed files.
The problem is if the nandroid didn't come from your phone, it doesn't seem to have a recognizable baseband and the cellular radio doesn't work. No radio=no connectivity. I took my phone back to 2.2.1 and initially had a bootloop. When I did a full wipe it booted normally into 2.2.1, but there was no signal in an area that normally has excellent signal and was working just moments before. So until someone helps us figure out how to work around this we are stuck.
Ok, so today I spent several hours playing with 2.3.3 and could not get a radio signal, so I recovered my 2.2.1 nandroid backup and all was well again. I decided to try Spike's 2.2.1 backup and it works fine also. So, it appears that it doesn't matter which phone the nandroid came from, the problem is going from one version to another. I wish we knew where the settings for the baseband are located.
Spike, just FYI, my 2.2.1 nandroid has live wallpapers, yours has some cool wallpapers I never saw before, but I didn't see any live ones. My backup also has all the bloatware restored.
I deleted my stock live wallpapers with titanium so i'm assuming thats why haha but its good to know that nandroids arent for just single phones. also when i flashed rjglenn's 2.3.3 i had several of his apps but i'm sure it wasnt all of them. so i'm assuming they are just apps that start on boot since they were in the boot file or he converted those to system apps. just little things i'm noticing as i learn. Still waiting for someone who knows what theyre talking about to come school us
Q: if I ever have to unroot and return my phone to Verizon to be replaced under warranty, how do I go back to stock recovery?
Just a guess, change the name of the installed-recovery.bak back to installed-recovery.sh and that should run a script that overwrites the GNM recovery with the stock one on reboot. I do not know if it will work and I'd be scared to death to try it.
No it won't work in reverse. The recovery-from-boot.p patch it calls will fail. You did dump your stock recovery right? If not and you used my installer script that script of mine dumped it for you.
Didn't the installer save it as another file, and the instructions said to move that file or it will get over written?
I've been lurking and studying up on this recovery. I've had my phone for about a month, but have been very conservative with monkeying with the phone rooting and debloating. The phone rebooted by itself twice last night, and tonight when I went to send a text message it just shut down. Now all it will do is vibrate when I try to turn it on. No video or audio. Verizon is sending a replacement under warranty. I assume that recovery would not help me, even if I had installed it, since the phone won't turn on. Am I wrong?
I was just becoming happy and comfortable with how I had the phone configured and set up. Bummer.
My first commando did that, rebooted and shut down at random. I'm on my second replacement device.
Recovery installed successfully! Thank you GNM! After bricking two commandos ( one while trying to install joneidy's 2.2.1 recovery) I was very leery to try this. Used the script & it was easy as 1-2-3! Made a Nandroid backup so now MAYBE I can recover next time I "f" something up. I appreciate all your work and look forward to a custom ROM to play with.
Install successfull. Thank you gnm! Once I have this installed...what do I use to unpack the system and boot files to change things?
Dsixda rom kitchen. On the 2.21 to 2.3.3 backups the radio/amss was updated by casio for 2.3 which is causing the no baseband issue when restoring 2.2 or vice versa. There is no current way to backup or flash a ams s/radio.img for this device nor any casio android product service tool available to flash a full firmware.
I am so happy to finally see a working, albeit not for me quite yet, recovery for my casio commando. I ran the script in the terminal emulator wit success however, my issue is that it runs the script and reboots my phone into recovery, its still just the triangle with droid and exclamation mark. Im in debugging mode and I plugged in my phone after which I turned usb to "charge only" and yet I am baffled. I tried this 5 times with no success other than the script ran and rebooted. Please help asap as I would love to have this on my phone. Thanks!!!!
I think I might have found the issue as to why the recovery isnt working. When I run the script a line pops up stating that there isnt a file "recovery.img" to be found. I thought this before. When i download the .zip for the commando recovery the only files that came with it were as follows: Readme, busybox, dump-recovery.img, dump-image, flash_image, reboot, and recoveryflash.sh. Again, there isnt a "recovery.img" file in the zip and I think that is the issue. Please help if you can! Thanks
