Don't try to use the Verizon updates through GNM's recovery, When you do and your phone restarts, you get constant messages that say that core system utilites need force closing, but here's the .dat file for M080:do someone have update.zip file, the official ones?
so i can update via this custom recovery
still on froyo
@ paxchristos- No, never tried, but that could work. No idea about the checksum, either. If you wanted to try to apply the update with stock un-spoofed recovery, you have to blank out parts that check for VZNavigator.apk and wGzWeatherWidget.apk (unless you didn't go on a total debloat rampage) or it won't even attempt to update. (this might go with all updates, so flashing the old recovery with the new .dat right after it downloads the original .dat file and then letting it update might let you get away with it, one could also make a M100 update with the Superuser.apk and su command in the update, thus giving you root with M100)
(at least in M070)Yup, it sure does. Is that the radio baseband update?
this file...
recovery-ra-commando-3.06-gnm.img
What is this file in /system, recovery-from-boot.p ?
this file...
You download this file. This is the recovery.img file specific for the commando
I lurked the all in one recovery thread by getitnowmarketing until I found the answer. I think I might have asked for it.
What now? Create a nand backup, and go to work f***ing up your phone knowing that you can always restore your nand. If something says -warning! May cause boot loops- go for it, cause you can revert back to your backup
