Hey guys.
I noticed that the CWM6 does NOT mount sd-ext correctly. I don't know if any of you guys use link2SD, but when doing backups, you can't back up sd-ext.
So I found a recovery from the CWM6 thread and made it flashable.
About the notice below: I somehow broke the link "recovery" from the block so in order for me to flash the recovery, I had to write it directly to the block.
DO NOT FLASH IF YOU ARE NOT USING AT&T FUSION 2 U8665! THIS WRITES DIRECTLY TO DEV/BLOCK/MMCBLK0P16 AND IF YOUR DEVICE HAS THE RECOVERY IN A DIFFERENT BLOCK, YOU COULD BRICK YOUR DEVICE! YOU HAVE BEEN WARNED!
