Root Recovery Help Needed
shaizi
I am trying to flash the stock recovery 2.22.401.5 on my HTC One M8 through fastboot method and found the results are as follows, but it does not take effect on the phone after I rebooted. What am I doing wrong?
C:\Fastboot>fastboot devices
HT43JWM06901 fastboot
C:\Fastboot>fastboot flash recovery recovery.img
target reported max download size of 1830711296 bytes
sending 'recovery' (24576 KB)...
OKAY [ 1.759s]
writing 'recovery'...
OKAY [ 1.035s]
finished. total time: 2.794s
C:\Fastboot>fastboot erase cache
******** Did you mean to fastboot format this partition?
erasing 'cache'...
OKAY [ 0.073s]
finished. total time: 0.074s
C:\Fastboot>fastboot reboot
rebooting...
finished. total time: 0.014s
Hello shaizi and welcome to AF. I moved your thread into the M8 area where it will be best served. Best of luck and thanks for joining and using these forums.
