Root Recovery help?
Hey guys i cant boot to recovery i try booting to it but just stays on "LG" any idea what to do?
Have you tried hitting volume down button? If you see the buttons flashing then hit the volume down. And recover will pop up.
It appears that you're bricked if the front keys aren't blinking. You'll need to follow my unbrick guide that is located as a sticky at the top of the main page of this forum. As I stated in my recovery guide you need to make sure you have the correct version of busybox 1.21.0. I recommend busybox by stericson just make sure you install the 1.21.0 and not 1.21.1. The version from xda site will brick your phone as well. If you've been able to get into recovery before try pulling out the battery and try again...
I must be lucky then....hmm I have v10d if that makes a difference? I have flawlessly been able to make backups and restoring etc from recovery...
