recovery.img
please any body tell me how i change these two recovery.img (star A1200 recovery.zip - 4shared.com - online file sharing and storage - download ... overy.html?)into one recovery.img.or tell me the concern software that i edit reovery.img.i mean i want to combine two recovery.img into one recovery.img.i want both recovery.img options in one place.
Not sure what you mean about combining "two" recovery images :dontknow:
Not signed up to 4share and was going to take a look at it-would it be possible to upload it to https://www.dropbox.com/ or https://www.box.com/
so I can take a look:confused:
Biggie, he wants to combine both so that he can have all the options of both the recoveries. I don't think combining recoveries is possible(is it?) just be editing.
A recovery.img is a bootable image that is written to the recovery partition on your Android device. It is built by compiling the desired recovery source (stock Android or from a custom recovery developer's source tree) as a component / portion of the whole Android operating system (you can get away with just recompiling just the recovery image).
However, that being said, merging two separate recoveries into one would require combining the sources and integrating (developing/testing/recompiling, etc.) their functions into one working recovery--its impossible to simply merge two existing recoveries or have more than one installed in your recovery partition at one time.
The "TL;DR" (too long; didn't read) answer to your question is: you can't.
Hope that was helpful.
Cheers!
