sammyz
LG Whiz Kid
Ok, well we have recovery, but some of us have no way to boot into it in an emergency situation (such as when you cannot boot device).
My solution? Flashing recovery onto the laf partition and using the download mode key combo works (volume up+usb). You only need USB power to get the key combo working, not a PC, so a charger will work. We can then either zero out the recovery partition or flash laf.img onto the recovery partition for fastboot/download mode (your choice). You're probably wondering why put anything onto the recovery partition if no access to it? Ahhhhh but that's where you're wrong. In cwm there's an advanced option to "reboot recovery" which will boot into the recovery partition which will now be either fastboot or download mode (depending on what you prefer).
How to use download mode keycombo to boot to recovery:
I'll probably add this option to my tool in this thread: http://androidforums.com/l70-all-things-root/863389-tool-lg-l70-laf-recovery-multitool.html
What do you all think?Confirmed, WORKING..here's how to do it
*Disclaimer: im not responsible for anything that happens to your device*
1. Plug in your device to your computer.
2. Open up command prompt.
3. Type adb shell and then su
4. Type
5. if youre recovery.img is not in /sdcard/ simply replace that path to where your recovery.img is on your phone and reboot into download modeCode:su dd if=/sdcard/recovery.img of=/dev/block/platform/msm_sdcc.1/by-name/lafshould put you into recovery
