wearespacepeople
Member
Cool, I'm thinking I'll back everything up and give this a shot, let you know how it goes
Hey Melll,
By heating your phone up in the oven, not to mention as hot as you got it afterward to where it was hot to the touch, you probably did internal damage. There's a reason electronics have a warning to not exceed usually 110 degrees F, as it will damage the TEMPERATURE SENSITIVE components inside such as resistors, thermistors, solder tabs, etc.
You may have gotten your phone to work for a while, but you've done irreparable damage to the internal components.
Source: I used to be a battery pack designer for Sanyo, MicroPower, etc. Currently I'm an I.T. / Server administrator and software engineer. I know electronics.
Phone works perfect, and it so hot that I couldnt pick it up, just hot enough that you can feel it hot.
Phone hasnt crashed, rebooted, or crash on me ever since I got it working.
It used to crash lots before, and now I got latest firmware updates and its all nice and good.
If this phone does die on me, I have warranty for 1 year, so I'm still not going to lose anything.
Im not worried at all![]()
No point in worrying anyway, what's done is done. I was only posting what I did so that nobody else does the same thing. "Hot to the touch" means it was still probably hotter than 110^F, which is bad news for electronics. I'm glad it worked out for you since this is a fantastic phone, but it's something that should cary a, "Do not try this at home" label.
I understand what you're saying.
Same thing could be said about overclocking computers and phones.
Which I think is worse because its for long term, which will heat up and damage the cpu/circuitry a lot more than a 5 minute warm up while the phone/computer is off.
Not true. When you overclock a computer, you are typically somebody who knows what you're doing. When you know what you're doing, you buy a good aftermarket CPU cooler that will perform better than what is needed. You also ensure adequate cooling for the chasis, and a nice airflow across the RAM modules. Computers and electronics such as smartphones by nature heat up to hotter than we think, but there are safeguards put into place that regulate those temperatures and modify how the device/computer operates during high temp times. If you increase the temperature on the components without these safeguards in place (such as, baking the phone in the oven when it is turned off), you are risking damage.
Let's not argue about the technical details here. I don't know what your knowledge on the matter is, but I do know what mine is. And the fact that you put your phone in the oven for 5 minutes twice leads me to have an assumption of yours. Let's just agree that this practice is not advised for most people, as it could damage the device in question. Sound good?
Again, I'm glad it worked for you, as I would hate to be without my Vibrant. It's just a very risky thing to do, especially when it's a $600 device that most people probably can't afford to replace right away.
I ageee that it is risky and dangerous.
People who want to attempt this probably shouldnt, and should try heating it up with a hair blow dryer for a few seconds at most, is what I would recommend.
But yeah, people are crazy and make tons of mistakes, but if nothing else works and you're desperate with no other options, I would definitely say, try heating it up with a hair blow dryer as its a lot safer and more controllable.
Sorry to say, but again, not sound advice. When you apply a wet-applied screen protector, there are countless threads informing users not to use a blow drier to dry your device quicker, as the same concept is at play here. Blow dryers blow air well over 110^F (so hot that you usually can't aim it at your skin, which is 98.6^F, for more than a few seconds).
The most sound advice is, depending on how you bricked your phone, get an insurance replacement or warranty replacement. Risking long-term damage to the internal components just to get it working temporarily isn't sound thinking.
Alright guys, here it is.
I was able to access recovery mode on my bricked phone in a way that all of you may think is stupid.
I have a Bell Canada Samsung Galaxy S Vibrant. My phone somehow bricked it self a few days ago. I wasnt able to get into recovery mode at all, no matter what I tried, how many times, and I tried every single method with no success.
People on XDA Forums were mentioning about heat somehow allowing you to access the recovery mode. Some said putting it facedown in the sun for a few minutes, some said plugging it in for 15-20 min, some said playing games on the phone to heat it will would also allow them to access the un-accessible recovery mode on their phone.
I tried all of them.
I put my phone in the oven for 5 minutes, twice, last night, did not work.
Ok I thoght to myself. Maybe I need more heat. To get it hot to the touch.
So I tried once again today, and what a shock, I was able to get in recovery mode via the 3 button - WITH BATTERY OUT, HOLD VOL UP + HOME BUTTON + POWER BUTTON, then insert battery, and let go of the power button once your phone turns on.
Took 3 seconds to set everything to restore, in the recovery mode.
And done.
It worked for me.
If you are going to try this, maybe try with a hair blow dryer first.
I dont have one of those, so I couldnt, to be safer.
I will not be held accountable for any damage you do if you leave it in too long or damage your phone in any way.
This worked for me. Im happy I got it working.
The only thing which worries me now........
What if heat or cold can cause your phone to brick itself?
My phone bricked itself out of nowhere, no idea how. And what if it happens again.....
I'm hoping I will not be "flamed by the heat advocates" in here, but I highly discourage anything having to do with an oven, microwave or open flame, etc.
Laying it in the sun? Maybe.. I would find other ways to remedy the issue.
I couldn't agree more!![]()
Heat+Electronics=![]()
IF (and this is a huge IF) heat were of ANY benefit (which I find highly doubtful) a blow dryer would be plenty (more than likely too much) heat to do the trick. But an oven? Absolutely NO WAY! Electronics technicians (TV repair, computer component, etc) have for decades used a "cold spray" to try to revive dead IC's etc. But heat? Never. Heck, there's even a hard disk drive recovery technique of placing the drive in the freezer and then attempting to recover data.![]()
No way would I put electronics in an oven of any kind.
This only works on older hard drives, FYI, and should not be tried on hard drives newer than roughly 5 years. It's based on the atomic particles of the metals in those hard drives coming closer together when cold, and therefore making the hard drive function for a small amount of time again (the real technical explanation is longer than I care to write)
Uh oh, you mentioned the hard drive trickThis only works on older hard drives, FYI, and should not be tried on hard drives newer than roughly 5 years. It's based on the atomic particles of the metals in those hard drives coming closer together when cold, and therefore making the hard drive function for a small amount of time again (the real technical explanation is longer than I care to write)
Even with older drives it was hit or miss, only helping under certain situations. I only mentioned that, in passing, as an unlikely example of a "thermal fix" that has any remote) credibility whatsoever - and even then it was utilizing COLD, definitely NOT HEAT!
