Root Recovery not backing up sd-ext
CdTDroiD
My Recovery is not backing up sd-ext I'm using clockwork 3.0.0.5 by I tried amonra and still doesn't. Any ideas why or how to fix?
What error does it gove when backing up ext? Or does it just appear to go through normally?
It was saying there is no sd-ext.img to restore, but i dont think it was backing it up in the first place. Maybe a 3.0.0.5 issue after a little googling. flashed 2.5.1.8 and seems to work fine. You using 3.0.0.5?
