Carlos1986
So I am still learning to use clockwork recovery and wanted to ask a few questions because I think I just killed my cm7 set-up. I flashed to cm7 using clockwork recover 2.5 and made a back up for safe keep and then I flashed to cm6 to play around with it. Now I was planning I keeping icarus 1.1,cm6,and cm7 so I can flash in between roms to demo to a close friend of mine. When I tried to flash my recovery of cm7 from cm6 it gave me a mismatch error. Could this be because of the fact I changed the recovery file's name to cm7 or because I need clockwork 3 to flash back to cm7.
I'm not sure I worded all that correctly if any confusion please ask and I will try to clarify.
Thanks, carlos.
The error message I get is md5 mismatch.
The other question I have is can you change the recovery roms file name or does this corrupt the data
Thanks, carlos.
