stevcha
Android Expert
Just wanted to post the features available in RA Recovery and Clockwork Recovery for those interested.
RA Recovery 2.3
[ Features ]
- full ADB access in recovery mode
- Busybox v1.15.3
- CM android-msm-2.6.35-unified kernel with ext3 + ext4 support
- SLCD and AMOLED support
- HW-Key navigation : Power + Volume -keys
- Extended menu :
- Reboot system now :: reboot your phone
- USB-MS Toggle :: enable/disable USB mass storage (use when the phone is connected to your PC)
- Backup/Restore
- Nand backup :: Make a selective Nandroid backup
- Nand restore :: Restore a Nandroid backup
- Backup Google proprietary system files :: Makes a backup of the Google proprietary system files in /cache/google
- Restore Google proprietary system files :: Restores the Google proprietary system files from /cache/google
- Flash zip from sdcard.
- Choose zip from sdcard :: Flash a zip update file from any (sub)-directory on your sdcard
- Toggle signature verification :: Toggles the signature verification for zip files.
- Wipe
- Wipe ALL userdata/factory reset :: wipes /data + /cache + entire ext partition + all apps installed on your sdcard.
- Wipe CACHE :: wipes /cache.
- Wipe DALVIK-CACHE :: wipes the dalvik-cache located in /cache + /data + /sd-ext is present.
- Wipe DATA :: wipes /data.
- Wipe SDCARD.android_secure :: wipes all apps installed on your sdcard.
- Wipe BOOT :: wipes boot partition.
- Wipe SYSTEM :: wipes system partition.
- Wipe SDCARD :: wipes FAT partition.
- Wipe SDEXT :: wipes EXT partition (if present).
- Wipe DATA:battery stats :: reset the battery calibration.
- Wipe DATA:rotate settings :: reset the sensor calibration.
- Partition sdcard
- Partition SD :: Interactive SD partitioning
- Repair SD:ext :: Repair the ext partition
- SD:ext2 to ext3 :: Convert ext2 to ext3
- SD:ext3 to ext4 :: Convert ext3 to ext4
- Mounts
- (Un)Mount /system
- (Un)Mount /cache
- (Un)Mount /data
- (Un)Mount /sd-ext
- (Un)Mount /sdcard
- Other
- Fix apk uid mismatches :: Does extacly that
- Move recovery.log to SD :: Moves the recovery log file to your sdcard. (Use when you want more detailed recovery
log information)
- Power off :: Powers off your phone
Clockwork Recovery
(Place holder)
RA Recovery 2.3
[ Features ]
- Busybox v1.15.3
- Extended menu :
- Backup/Restore
- Wipe
- Partition sdcard
- Mounts
- (Un)Mount /system
- (Un)Mount /cache
- (Un)Mount /data
- (Un)Mount /sd-ext
- (Un)Mount /sdcard
- Other
log information)
Clockwork Recovery
(Place holder)
