Root Recovery Screen
BenDroid
Alright, I am trying to root a friend's captivate but am unable to get to the recovery screen no matter what I do. We have tried every variation of keys. I have held the power, vup and vdown and let go of the power as soon as we see Att. I have held them all for minutes at a time. We have tried holding one or the other volume keys. No recovery screen.
I have also tried using the "one-click" option provided over at xda. I installed the correct drivers, turned on USB Debug, and got no where with the program. I shows that it pushes the "update.zip" file to the sdcard, but does not reboot the phone into recovery to give me the opportunity to apply the update.
My friend has tried a couple of different market root options...one called lagfix of something like that. It was a no go either.
Anyone have any ideas as to what I am doing wrong?
I understand most root concepts. I personally own a Droid (verizon) and have had it rooted/ROM'd since day one. I am just new to the captivate and am unsure of any other methods to get to the recovery screen to flash the update file besides maybe SDK.
Thanks for any helpful tips/comments.
Ben
if you search the market for "oclf" there is an app that has an option to root, it also has an option to lag fix but that is completely optional. but once its rooted i would install rom manager and flash clockwork recovery so you can get into recovery mode that way. ive heard of a few people that cant get to recovery any other way
Hold all three buttons until the AT&T screen comes on. BUT DON'T LET GO YET!
Keep holding it until it goes away, and then comes back - let go after it comes back a second time.
Should get you there.
First of all...thanks for all the helpful comments. As an update, I just downloaded the OCLF to his phone via marketplace. Ran the root option. Nothing happened. It didn't show that it did anything. It did not request for the phone to be rebooted into recovery or anything. I am guessing the script that it runs just forces a superuser/update.zip file to the sdcard and from there you have to boot into the recovery screen to apply the update.
The problem that we are having is not getting the file on the sdcard. I have downloaded the "Unleash the Beast" file. I have manually placed a standard "root" file on the root of the sdcard. I have tried the root method provided by xda. I have now tried the OCLF method. All of which placed a file on the sdcard. (I deleted each one between tries, so there are no duplicates). The problem we have is no matter how we try it, we can't get to the recovery screen.
I have held all three buttons through the ATT screen and the screen will blink and then go back to the ATT screen and so forth and so on as long as I hold the buttons. The moment I let go of the power button though it just completes the boot process. I have tried letting go of the power button as soon as the ATT screen comes on and then let go of the power button. I have truly tried every method I can think of.
Please let me know if you guys have any other ideas.
Thanks
Ben
