[recovery] twrp 2.2.2.0
colchiro
Extreme Android User
[RECOVERY]TWRP 2.2.2.0 touch recovery [2012-08-24] - HP Touchpad Android Development - RootzWiki
CHANGELOG (for 2.2.2.0 compared to 2.2.0.0):
Mostly bugfixes:
Significantly improved sd-ext handling (ext partitions on sdcards)
Changes to kinetic scrolling in file selectors
Fixed a problem with using periods in backup names
Fixed problems in XML layouts with mounting system and USB storage
Fixed a problem with unmounting a partition before formatting during restore
Add Jelly Bean decrypt support
Updated 320x480 theme to match others (thanks to Llewelyn)
Improve "symlinking" of /data/media to either /sdcard or /emmc
Added sanitizing of device IDs for invalid characters (thanks to bigbiff)
Fixed free space calculation when switching backup devices on /data/media devices
Fixed a problem with using OpenRecoveryScript to create a backup without providing a backup name
DOWNLOAD:
The fastest and easiest way to install TWRP is to use the GooManager app:
Play Store Link
Direct Download
1) Install GooManager from the Play Store
2) Open GooManager and provide root permissions
3) Hit Menu (or the button with the 3 dots on your screen) and then Install OpenRecovery
OR:
You can find more information and download links on our website!
NOTE: If you're coming from another build of TWRP, you may need to go into settings and tap reset defaults to reset the storage paths so that you can see your zip files.
