messi2050
WARNING:
The stock boot image has dm-verity, which prevents you from booting if you swipe to enable system modifications after flashing twrp!
SOLUTION:
Flash a root such as SuperSU or phh-superuser. You should also flash no-verity-opt-encrypt.zip.
Prerequisites :
Enable OEM Unlocking and usb debugging in developer options!
• YOUR BOOTLOADER MUST BE UNLOCKED
- reboot into fastboot [ adb reboot bootloader ]
- fastboot oem unlock [ this is going to wipe your data ]
If you have problems with the device drivers installed , you will need to install lg bridge app from lg that contains the device driver
http://tool.lime.gdms.lge.com/dn/downloader.dev?fileKey=PWZO7A26B9UW
How to flash the recovery:
• BOOT INTO FASTBOOT MODE:
With your phone off, connect your usb cable to your phone while holding VOLUME DOWN to boot into fastboot mode or just type [adb reboot bootloader] in the adb terminal
• ONCE YOU ARE IN FASTBOOT MODE:
Open a command prompt and type "fastboot flash recovery <path_to_recovery.img>” without the quotation marks.
Example: fastboot flash recovery C:/Users/John/Desktop/recovery.img
[don't forget to extract the downloaded recovery zip to get the recovery.img]
• WHEN THE FLASH COMPLETES: (Takes about 2 seconds)
On your phone, unplug the usb cable and power it off by taking out the battery and putting it back in.
• BOOT INTO RECOVERY MODE FOR THE FIRST TIME
HOLD VOLUME DOWN + POWER until you see the LG logo and then temporarily release the POWER button, immediately pressing and holding it back down until you see the white prompt [factory reset] screen. You will NEVER release the volume down button in this process!
Use the hard keys to select "YES" and then "YES" again to boot into TWRP!
How to Disable encryption & flash super su
1. In TWRP, go to Wipe > Format Data. Enter the keyword ‘yes‘, in the provided space and enter. This will wipe the automatically encrypted filesystem, and decrypt it.
2. Once the wiping is done, reboot back into recovery. Go to Reboot > Recovery.
3. When the recovery boots again, connect your phone to the PC and Enable MTP under the Mount section.
4. Transfer the downloaded ‘no-verity-opt-encrypt-2.1.zip’ and ‘SR1-SuperSU-v2.78-SR1-20160915123031.zip to your internal storage or EXTSD
5. Disconnect the device now.
6. Tap on Install. Now, navigate your phone’s storage and select ‘no-verity-opt-encrypt-2.1.zip’. Finally swipe the ‘Swipe to confirm Flash’ button on the bottom of the screen.
7. The flashing process will merely take a few seconds. And when it’s done, follow the same method to flash the root package – SR1-SuperSU-v2.78-SR1-20160915123031.zip
Wait 1 or 2 minutes after the zip files are done flashing then reboot system and PROFIT! Your phone may take 3-5 minutes to boot the first time and it might boot-loop once or twice at the Metro PCS splash screen but don’t worry this is expected.
All required files [supersu+dm-verify disable] can be found in this thread :
https://forum.xda-developers.com/lg-g5/development/recovery-team-win-recovery-project-lg-g5-t3363047
Download :
#2 build [stable]
http://www.mediafire.com/file/x1bo7scmrga40q5/lg_aristo_twrp_v3_stable_build_by_messi2050.zip
#2 build Changelog:
-fixed device gets wiped everytime you use the hardware buttons to boot into twrp.
-fixed flashing boot/recovery images through twrp
-built using latest twrp source.
[do not mirror the downloads]
Notice: After the TWRP splash screen you will see the option to type in the password to decrypt the filesystem. just ignore it and hit the cancel button.
Please note I don't own this device and spend a lot of my free time bringing these builds for you to use and benefit from So Please Consider donating using the link below if you appreciate my work.
https://www.paypal.me/messi2050
I reflashed TWRP and used the format userdata and cache fastboot commands and I am now able to boot into TWRP. Once there, I restored the backup I made, cleared cache again and I no longer see the "Encryption unsuccessful" screen. My new issue is the phone gets stuck at the LG boot screen. Maybe, I'll need to flash the stock boot image? I'll try a few things and report back.
