You still need that partition backup bud? I got this thing fresh installed twrp and magisk, userdata untouched.Hi everyone,
I really need a favor,
I accidentally killed my phone messing with lgup and I know the problem is the userdata partition, I need someone to dump only the userdata partition using LguP so I can flash it to my phone and get it out of Factory reset status 2 mode...
If anyone here has the m210 and is willing to help me I can give you my modded LgUp so that you can dump the partitions and flash individual partition etc.
PLease if youre willing to help and you have the aristo m2120 lv3 please pm me...
it's this one
PLEASE HELP.
Astr4y4L
i managed to extract the stuff i needed from a kdz 1FYI latest magisk doesn't seem to install...
It does work, just requires a reboot! Also safetynet passes perfectly (afaik the dm verity doesn't need to be flashed since it's already in the magisk zip, but you didn't hear that from me xD)
Cheers. This is good info for anyone else that runs into this problem.i managed to extract the stuff i needed from a kdz 1
thanks tho
did you enable mtp? what exactly does the error say?After I install twrp, I flash no-verity-opt-encrypt-2.1.zip, but I still get can't mount data. I have rebooted back into recovery, shut down and booted into recovery, but I still have no luck.
failed to mount '/data' (no such device)
hmmm there's not much out there for
Code:failed to mount '/data' (no such device)
have you tried and re-download the file?
