Accessories Red 1800mah battery for 14.99
Mike304
Hi,
At first I decided to ask if anyone had purchased this battery or could recommend any good one but since not I've decided to go on ahead with purchasing this battery after reading good reviews from the buyers of this item. If all goes well I should be recieving this battery next week to compare the battery life between this battery and the stock battery the dread 1300mah. In case anyone is intrested or has bought the battery and would like to give feedback please do. It even keeps the red theme going!
HTC EVO 4G BATTERY 1800+Dock USB CHGR SPRINT TOUCH PRO2 - eBay (item 320564426715 end time Jul-27-10 10:48:34 PDT)
Or
HTC DROID INCREDIBLE VERIZON 2x1800 Battery+Dock CHGR - eBay (item 320565812773 end time Jul-30-10 14:08:37 PDT)
Thanks,
Mike
It's actually a 1500mAh battery, just so you know..
Whr / 3.7 = mAh
Yep. Definitely not an OEM HTC battery either. That math fallacy would already have me doubting if it would meet the claim at all. It's a good deal, if it were a decent 1500mAh. I'd just get the real TP2 1500mAh.
So by dividing whr by the voltage it gives you the mah?
Yes. Watts are simply voltage times current (amps). Since mAh represents how long it can give off a certain amount of current you can just take the "hr" on the end of it. So, dividing the Whr by the voltage gives you the mAh.
iv been using a battery from the imagio and i get thru the day no issues. so far this is my 4th day using it and it gets better day after day. along with the bump charging. so far today at 7pm im at 52% normally id be at 20% or less. and i am a very heavy data user.
the battery is the same from the htc ozone, imagio, touch pro, touch pro 2 it is a 1500 mah batt and it fits in the same spot the stock 1300mah fits.
