Reduce Battery Drain ^^.
was this tutorial useful?
  • Yes
    Votes: 10 83.3%
  • No
    Votes: 0 0.0%
  • Helped but Not Sure
    Votes: 2 16.7%
  • Total voters
    12
suhel28
when I bought x8 I was shocked the way the battery used to get empty every 2hours but than few minor settings have considerably increased my battery life.
Things you can do :
  1. Widgets
    press the menu key and add the following widgets on your home screen
    1. Data Traffic
    2. Power Control
    3. ATK (if installed/optional)
    DATA TRAFFIC & Power Control:
    what do they do?
    Data Traffic is basically related to your network internet. when you've it enabled it, you'll be able to use your network internet. if its turned off you wont be able to connect to the internet.
    what it is helpful?
    Xperia by default automatically updates a few applications or if you've some applications installed (facebook, gmail, etc) which automatically do updates than if data traffic is enabled it will allow those applications to update without even asking!!!!
    so you'll never know that your battery is draining in your pocket even though you haven't used it.
    Trust me. Gprs uses lotsa battery. so whenever you don't need GPRS just tap the data traffic button on your homescreen (the center button in th below screenshot) and your phone wont be able to use GPRS without your permission :D
    2. Power Control
    Its a very handy widget. it shows you (the topmost line in the image) buttons for quickly turning on/off wi-fi, bluetooth, gps, backgroundsync, brightness
    you guessed it right. whenever you don't need the above things simply turn them off.
    keep a habit of turning off WIFI & GPS when not in use. they're the major culprits in battery drain
  2. SETTINGS
    time for some quick settings.
    things to be changed
    1. Brightness.
    2. GPS
    3. Synchronization
    1. BRIGHTNESS
    this may get you a bit dishearten but keep the brightness level to zero (not in real cuz you can easily see things unlike nokia phones where zero brightness makes you blind lol)
    just remember this guru mantra
    the more BRIGHT your phone, the more it EATS your BATTERY
    but the choice is yours :D
    2. GPS
    Although the power control button will give you a quick way of ON/OFF it will only turn off the integrated GPS option OFF but the wireless gps option will be still turned ON.
    so whenever you don't need GPS make sure both of them are turned off
    2. AutoSync
    no explanation for this. simply turn it off. its of no use (atleast for me)
  3. ADVANCED TASK KILLER FREE (Attached)
there has been a lot of debate over ADVANCED TASK KILLER that whether you should install it or not????
personally I love this thing. Its like a superman for my phone but thats just personal opinion
ok if you've installed ATK than read below
first thing is first you'll have to add its widget on your homescreen​
SETTINGS IN ATK
1. Ignore List
2. Autokill
IGNORE LIST
before you start using ATK ignore the following two application from getting killed
1. ATK (self explanatory)
2. Back Up & Restore
the second thing is interesting.
you may wonder why to keep it in ignore
but I've a reason. earlier when I started using ATK as soon as it killed backup&restore. my sim card used to get reset as if I've restarted my phone. its weird why it happens but to be on a safe side. let the baby live
HOW TO IGNORE APPLICATIONS??
in your ATK screen. tap & hold (long tap) the application you want to ignore and select the ignore option
AUTO KILL
ok now you dont want to again and again go & open ATK and kill applications.
so you can choose AUTOKILL
you'll get two options in AUTOKILL option
1. AutoKill Level
2. AutoKill Frequency
AUTOKILL LEVEL
as you can see there are three options there
  1. Safe
  2. Aggressive
  3. Crazy
CHOOSE : SAFE
Safe :
Only kill the apps that aren't running but still consume memory
Aggressive :
Kill the apps running background and apps aren't running
Crazy :
All apps except for apps you are using with
AUTOKILL FREQUENCY
select that option to kill unused applications (which you've exited but still running as not all applications have quit option) whenever your phone is autolocked (screen time out)
USE OF ATK WIDGET :
well whenever you feel like you're phone is getting closed
[or]
you've opened a lots of applications and closed them (not exited them ofcourse) just click the ATK widget and Shhhhhh... it will kill all those not-in-use applications.
-END-
the above things have worked for me and now I enjoy longer battery life. however its not the only thing you can do there are lots of other stuff. if you've any more ideas share them.
USING ATK IS YOUR CHOICE I DO NOT FORCE YOU TO USE IT
hope you liked my clumsy tutorial
Hei thanks a lot for this threat! I didn't even know about the autokill feature, i was all the time killing manually the sonyericsson aplications (btw it's possible to remove them? i hate seeing roadsync all the time!). Usefull post!
greetings from spain!
hello amigo :D
yes there is a way to remove the default applications..
but you need to root your phone for that
how to do it ???
here is the link
http://androidforums.com/x8-all-things-root/213237-root-unroot-x8-detailed-explanation.html
after you root your phone install titanium backup application from the market it will help you remove and backup your applications :)
thanks again! Just one thing, if i root the cell, i remove the apps and then i unroot it, will them come back? I don't know why, but i've read on the internet that there are a few stability problems rooting the phone.
Thanks for your help!
if you've backedup them u can always install them back...
Erm I don't know about the stability probs..
Thanks for your time writing this mini guide!
The only issue is that without Background Data ON,
the Market doesnt work! ;)
N.
you can always use the power control widget .. just one tap and background thing is enabled :-)
Thats like 2 seconds each time I need the market!
In other words,its like 10 seconds every day or 3650secs every year!
:D:D:D
Just joking! You re right! ;)
N.
PS.Btw,just by not using Beautiful Home Weather Widget I got like +50% more uptime! I m not joking! We re talking about more than 10hours...:eek:
Also, not to correct but to add to your tutorial, I'm using Watchdog (Lite). It allows you to see the usage of processing power, also with high usage alerts. By using this, I can check if I have any battery consuming app.
This app kind of kills the need for APK since it can task kill.
THANKS I'll check it out :-)
Turn your phone to airplane mode-significantly saves a lot of power. You will be offline but this is perfect if you don't want to receive incoming calls or messages or if you're hiding from someone...
live wallpapers are battery drainers!!!!
i used to run live wallpapers, and i noticed that with my regular use (wifi, music, sms), my battery just lasts < 24 hrs! But with ordinary wallpapers, the battery lasts for two days!
hey guys..there is error in my phone..when i charge it my status bar is not working anymore,,i factory reset and all the things that i can do to fix it..but it is still not working..can you please help me to fix it??plsss guys:(
