I use this for Perk and want to free up memory so Perk will crash less. Is there anything I can uninstall or disable? I don't use this device for anything else.
There's several stock apps that can be uninstalled or disabled in the Apps part of the settings. If that's not enough, you'll have to root to remove anything else. Check the guide in the root forum for instructions.
Unlike any task killer or other battery savers, ShutApp saves your battery life in a unique but quite effective way.
It can do only one thing, that is to detect and shut down lurking background apps on your android phones or tablets. In this way, ShutApp makes huge difference to your battery life.
I tried it, it works I guess, but it of course turns off some background stuff that you don't want turned off. Didn't bother to check if there were exceptions allowed – that's your job.
