Root Redux 1.2 noob sd partition
hi
i've recently got a HTC desire with Redux 1.2 installed and i'm having trouble with internal memory.
Iv'e searched through the forum and can't seem to make any sense of it :)
I rebooted the desire putting it into recovery and looked through the options and in advanced it says partition SD card.
if I want to increase the partition that acts as internal memory do i just select this or is it more complicated than that.
i've looked at the FAQ but cannot make much sense of it:confused:
If i go into recovery and select advanced and then select partition SD, will that increase the internal memory?
sorry as i said i'm a newbie :D
No.
First get something like FreeSpace to understand the Available/Free Space in your phone (internal/external).
Then, make sure you have tow partitions on SD card: one FAT32 and one ext3 (to be created by Gparted).
Restart the phone and check again the Available/Free space allocation.
As a final step, you flash the a2sd+ file for Redux to move Dalvik cache to SD card.
Hey me again. How do I know if the apps are installed on the ext4 partition. I've got freespace and the apps are currently install on the phone.
Use Quick system info. See if the a2sd storage shows free less than total.
This is all in the faqs
Of course they are, otherwise it would be 0.00MB used.
0.76 indicates it is working. Did you flash teh dalvik script too or not yet?
I got the figures mixed up sorry :rolleyes:
theres about 1GB ext4, theres 802MB free :D
yes i flashed the dalvik script straight after i completed the partition.
