Root Redux 1.2
ducky1979
Android Expert
Just flashed redux and I have to say I am very very impressed with it so far, I installed all my apps as before and gained 40mb? Just wondering how you use a theme for it? Do you have to flash them?
SUroot, can you provide some pics and a link for your theme please.
Also it seems so much quicker even loading web pages and the like, not tested battery out fully yet, can someone recommend a govener setting and optimal CPU settings, I'm using manu 1.4.
I guess it is all down to you and how well your phone works with the settings you have. I have the ManU kernel also and for the CPU settings I have Screenstate scaling ticked, Governor is ONDEMAND, Minimum frequency is 245 and the Maximum is 1113 and the set to boot is off [I think you need it on if you change settings in order for new settings to kick in at the next reboot]. I don't use setCPU and am happy with these settings. battery life is definitely better for me. Others may have other ideas.
Ive taken the theme down as I have asked the original author of the theme chooser theme if I can use his images and as yet no response.
