Root Redux Question(s)
Dudditz
1 - I have partitioned my SD, plenty of apps installed (more than I could get on stock) but I am now down to 50mb on the phones storage. All I have is what I used to have when on LeeDroid yet I had around 90mb of storage left on that.
I take it I should flash the app_davlik2ext zip and this will sort it out? Do I just flash that or do I need to do anything else?
2 - Although I have only been using this today, the battery seems worse. Normal usage, nothing syncing in the background etc (set up the way it was with LeeDroid). Willing to see how it goes over the next few days but is there another kernel I should look at?
Tried to have a look through the thread on xda but there was a lot in there :D
Must say, after adding the ManU Kernel the battery has been pretty solid.
Battered it yesterday, got 17 hours out of it with around an hours browsing/tapatalk, 2 hours on the Vevo app, around an hours calls, a dozen or so texts, and some angrybirds, air control, FB, Pulse etc.
