refurbished droids
This discussion popped up in another thread. To be honest a refurb is probably better than a new one, because a refurb has to go through stringent tests where as a new phone doesn't.
Like the guy above said if it doesn't appear like it from the outside, it's not worth worrying about :D
well thanks for the replies, but these replies DO NOT answer my QUESTION. i am in no way interested in someone explaining to me why a refurb is a good phone. this question is quite simple. IS THERE A WAY TO EASILY TELL IF YOUR MOTO DROID IS A REFURB?
Depends where you get it from. At the Verizon store, the refurb will come in a white box, and usually has a clear film on the screen with wording stating it is a refurb.
Why do you want to know?
yes,
just call into customer care and ask if your ESN number has ever been previously activated. They keep a record for warantee purposes. If you BOUGHT a refurb, you have a 3 month warranty. If you bought what you though to be a new phone, and actually got a refurb, then you have NO warranty.
ok thanks. where do i find the esn #. im not seein one. the reason im wonderin is cause im gettin several issues with my 2nd droid i didnt have with the first one. check my other posts. 3g issues r drivin me insane. this one seems to lag out alot and having all kinds of little issues.
