Regarding 3.5 audio jack issue
pnag1003
Hi all,
I am using karbonn a9+ (not famous like others :P)ICS 4.0.4 based phone
headset originally provided is working fine but quality is not good .
I have i5 apple headset .its working fine with which are all device compatible with 3.5 jack but not my with device
when I insert to mobile ,icon will be appearing but when i start playing sounds with higher volume playing will be stopped .
I searched many websites , some where i read - The problem is exist with many ICS based set .
If keep low volume - no problem song will be playing but performance is the matter !!
Kindly suggest solution for this problem.
I have a few devices that do that at high volume as well. I believe the headset is the actual problem, it just cant handle the higher volumes.
I believe (but don't know for sure) that some headsets are made to limit sound to stop people going deaf from too much volume for too long.
Can someone with more knowledge about this either confirm or deny this?
i also tht it's related to jack . But somewhere I read its due to software issue .
aroundsound etc are the soln for some handset but i m not lucky
