reilus
I was using Root Uninstaller and I tried to uninstall Boingo. It kept giving me a pop up window saying the program had to force close. I would force close it and it would keep showing the pop up. I had backed it up, so I tried to uninstall it, but I kept getting the pop up.
When I finally rebooted to stop the endless pop up loop, the program was gone. I still have the backup in my sd card, but when I go to install it as a system app, it won't go into the system.
Do I need this system app to update to 2.3 when that comes out? How do I get boingo back into the system if I want? Is there a stock rom for the LG Optimus M with instructions on how to reinstall all the stock stuff?
There was a thread called "Accidently erased your apks? Download them here!" But I can't find that and I think that might help.
Thank you for your help.
Updating from 2.2 to 2..2.1 puts all the bloatware back, so updating to 2.3 (when available) will probably do the same.
