Root [RELAUNCH][ROM] Blue Terror
aayushdutta
Hey Guys,
First of all, Glad to meet you all after such a long long gap of about an year in ADProgrammer Developments. I've been very busy with my studies settling down in my college. Now I'm all ready for the next phase of my developments in the Micromax A75 Series.
First of all, I am glad to inform you all that Micromax A75's First ICS Theme Customized Built from Scratch ROM i.e. your own Blue Terror
Bro just need to know as i have the zip of Blue Terror V1.1 with all the OTA but when i flashed them now i just stuck on bootloops so is there any changes in the downloads provided in the above link or they are all the same zip what i had preserved. If these are different then will download them else will just download what u ask me to download.;)
Ummm... Bro, If you want a combined ROM, I first need to open my old DropBox Account, then I would start OTA Server only. So that you can get the updates live... no need for coming here...
Just a few days... maybe 2 at max...
Don't worry, I am back now.. I'll do it... Making Android Developments my life once again... :)
Aayush
Aayush
Okay so that means i dont have to download the Blue Terror V1.1 as its the same what i have on my PC correct.
brother thanx for the ROM but previously i used anarchy reloaded ROM & i switched back on it as i don't liked blue terror in any means
hope you can provide me ota updates for anarchy reloaded ............
It's completely fine, many like you don't like the ROM. Nothing new for me.
And as far as I am concerned, I am the developer of Blue Terror so you gotta ask the developer of Anarchy Reloaded to provide you with the OTA for that ROM.
Thanks.
Thanks.
Hey Dude...
I like ur rom so much that even i cant describe it, m using it from when it was first launch for MMX a73, even after the realese of anarchy i luvd blue terror more as it was our first rom without bugs...
there is a problem with holo locker....during the call conversations screen locked automatically with holo locker. for ending call frist i unlock screen then I press end call button ..... any suggestions pls.....
I Hope That My ROM would again be Loved by All! :)
Regards
Aayush Dutta (ADProgrammer)
New Delhi, IN
This is for sure Aayush that Blue Terror is just one of its kind as its the Stock MODDED ROM so it will be always loved by each and every ROM lover dont belive me so check this out...
...I am back on Blue Terror with all d updates flashed and its running smoother than before feels like i am having the best phone ever. Thanks Aayush for Blue Terror. The screenshots will prove everything so here they are...
Buddy can you let us know how to Odex the ROM so that we can Odex it and use it as if after Odexing can use the int2ext by mastermind without any problem on it although there is a int2ext+deodxed but the processing will be a little bit slower then the odex version. I am just loving my phone thanks Ayush for this lovely ROM.
This is just an awesome ROM i dont know why my phone is running faster than before and its pleasure to use it on Blue Terror.
Wow it looks cool with the new icons pack and specially the notification bar ... Did u created???
No I dint created d notification bar its only d build prop edit what I did to get this notification bar n yes I changed d icon pack.
