adrynalyne
Android Expert
Finally,
The moment all of you have been waiting for. DL09 has been officially released. Well, by us anyway.
What does it fix? I have no idea!
I extracted it, and:
-Doedexed
-Zipaligned
-De-Binged (save browser default search)
-De-bloated
-Includes busybox 1.19 compiled by me, that can ping by FQDN.
-Rooted, of course.
I also edited the sound when you touch the screeen. If you don't like it, the old copy can be reverted back. Its in system/media/audio/ui. Attached is a cwm patch to revert to the old sound. Takes like 5 seconds to run, tops.
Note:
-Maps is not included, it must be downloaded from the market.
Is it an official update? No. Will it ever see the light of day? Quite possibly. Will it void your warranty? Definitely. Is it worth it? Maybe.
You need to be rooted to install this update and have access to clockworkmod. Data wipe is essential. Voodoo needs to be REMOVED PROPERLY prior to installing this update. All parts should be installed, or things will stop working...such as haptic feedback, and sms. DJ05 and DL09 radios appear to be interchangeable, but heavy testing has not been conducted.
There are three parts.
Radio:
http://adrynalyne.us/files/roms/DL09modem.tar
This gets flashed via Odin, in the PDA section.
System/rom:
http://adrynalyne.us/files/roms/DL09_2.zip
Mirror:
www.eleazar.org/Adrynalyne/DL09_2.zip
This gets flashed via clockwork.
Kernel:
Non-voodoo
http://adrynalyne.us/files/roms/1230_NON_voodoo.zip
Voodoo:
http://adrynalyne.us/files/roms/1230_Voodoo.zip
Note- Both of these kernels are similar to my previous test kernels, except they include boot animations. They are undervolted, and based of of jt1134's source on github. DJ05 kernels will work fine for DL09, but you should supply your own boot animation if you do not use one of the above. The stock boot animation does not work very well.
https://github.com/adrynalyne
These get flashed via clockwork.
Thats it.
Some notes:
Do not flash anything made for DI01 or DJ05 with DL09. You are asking for stupid things to happen.
DO flash stuff made for DL09, if you can find it.
This is not froyo, its 2.1, but a bugfix to hold us over.
No warranty given, implied, or anything else. You are on your own!
I apologize if glitches are found, not a lot of testing was conducted.
All the devs on IRC, and the original leaker, god rest his soul (we buried his bones after picking him clean after the DJ05 leak).
-Doedexed
-Zipaligned
-De-bloated
-Rooted, of course.
Note:
Radio:
System/rom:
Mirror:
Kernel:
Non-voodoo
Voodoo:
Thats it.
Some notes:
