Catlog is there to benefit the whole community. If you find a bug while using reloaded, catlog is able to record everything that the phone is doing for a short period of time so that you can send the report to the dev and he can see exactly what happened that caused it.
Terminal emulator allows you to run command prompts straight from the phone. Its useful for keeping a2sd in check as well as a variety of other things.
Yes, the hotspot will work with the screen off.
Hope this helps
