Remember that Gold Baterry?..
If anyone was still thinking about it, check this out:
High Capacity Gold Battery - YouTube
edit: My apologies, I posted in the wrong forum. If a guide/mod happens across this, please move it to the correct forum. Much thx.
dude...if you purchased it from Amazon and it is not working as you were promised the file an A-Z guarantee...you'll get your money back...Amazon tends to support the buyer more than the seller...i know this because i am an amazon merchant, that is what i do for work...
Yea, but I just didn't want to deal with it.
I recently bought a Motion for my girlfriend, so I decided to keep it charged and stowed in my backpack so we can swap out in an emergency at work or something since we can both use it now.
I was itching to see what was under the gold wrapper since I first took it out of the package. Since the decision was made to keep it, I just wanted to make this vid for everyone as I was going to unwrap it either way.
you should post this video on to the Amazon review..
and no offense...but i kept waiting for you to cut your finger off or something :P
Thanks. You mentioned it was ironic that you were recording that video with your Motion. I was watching your video on my Motion, even more irony. ;)
And even MORE ironic -I was watching the Video on my Motion also
while sitting on a big fake gold pillow
shaped exactly like the fake gold battery.....
That is alot of gold , Even more ironic is that I read your conversation on a motion! (Or a rock.... Which one again??)
Just a little word of educated advice:
You can only pack "so much" energy into any given amount of realestate, aka - the size of the battery.
In the past... we'd see some batteries with "spacers" that would fill a larger compartment (Nokia did this years ago, famously... in the early-mid 1990's). The idea was to then sell a full battery as the "Extended" one... when actually they only gave you a crippled one with the phone to start with.
These days - its all about size. The energy density is as high as current technology can handle. Any batter that claims to be "high capacity" when it fits in the exact same space, is in fact... not high capacity.
How do they get away with it? The secret is how they measure the "capacity" in mAh. You can measure the battery at current loads that are approximately the same as the phone uses, and get a true mAh result. Or, you can cheat, and measure the battery at such microscopically low drain conditions that the numbers are skewed.
This is similar to those tiny yet very high wattage computer speakers you'd see years ago. They'd skew the time frame of the reading, to make it "seem like" for that one brief instant (less than a millisecond) that 2w monolithic amp chip was dumping out 150w of power.
Measurement trickery.
