Remote access on A500?
kristalsoldier
Hi...
Do you folks regularly remote access your computer through your A500? What do you use? I believe TeamViewer is good - your views on this?
And, if you are using a data connection, does remoting consume a lot of data?
Thanks
I've never really tried it with my Acer yet. I have done it with my Droid cell phone.
I had a real good app for this I will look for it tonight andtry it on the tablet and let you know.
I tried Team Viewer last evening and it was easy to use and somewhat uncanny. I really need to check out he date consumption. If it appears high maybe I will upgrade my plan. I'll try the other ones later today.
