Look on eBay they are everywhere. At a couple of dollars a piece even though they can be reapplied, you probably have trouble keeping the dust out. Most of them attach without adhesive and use electrostatic type adhesion. Search for "S4 Screen Protector" and you will spend hours going through them!
But I want a good quality one that I can take off and then a week later reapply
Most of the good quality ones are 'good' because they have good adhesion, and are strong enough to prevent scratches. When you take it off, you will lose adhesion, so it is likely not going to be 'as good as new' anymore.
Just out of curiosity, why do you want to remove/reapply a screen protector? There are cases out there that have a built in screen protector (like otterbox defender)
