Yes you can and you don't need to have a rooted phone.
Just use an app called folder organizer,you can create folders change the icons of apps and remove the text among other things.
Yes this is true and it doesn't have to be the paid version. The important thing is to make sure you add as a widget.Folder Oraniser certainly allows you to remove lables
Long press
Widgets
Folder Organiser item
App
Then untick "show text under item"
Select app
Long press
Widgets
App
Select app
Long press
Widgets
App
Select app
