Remove Bloatware on a rooted 3g MT
TuesdayClub
Member
Rooted and using Cyanogen w/ Root Explorer...How do I remove Amazon mp3. et al from the phone (bloatware)? I use RE and it still shows...SadFace.
Well you said mytouch 3g but i'll asume you meant mytouch 3g slide. If so, you have to do it through clockwork recovery and mount the system. Root explorer won't do it as we can only write to system through clockwork because it's the only way to mount it.
